In your case, if they're recent Samsungs, all you need is wifi and you can access everything through the TVs without any additional hardware.
HD TV antenna?
Re: HD TV antenna?
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
Re: HD TV antenna?
OK....on my 405, I found the antenna amplifier and the OEM antenna with the light on. I switched the antenna switch over to the OEM side and ran a channel search on my new Samsung smart TV. I only found two channels using the old system, I have 28 using my dock mounted hi def system. Any suggestions? Maybe a Shakespeare system on the radar arch?
- Been thanked: 1114 times
Re: HD TV antenna?
I wonder if that amp is any good, even if the light is on.
What is your "dock mounted hi def system"? If it is an antenna and there is no amp on that system, then I'd take the input to the amp (which should/would come from the antenna) and jumper it straight to the input of one of the TVs, and rescan. If you pick up more channels, then I'd probably replace the amp.
