Depth Sounder Has Died
mbenner
Vessel Info: 1993 Carver 300 Aft Cabin
Post by mbenner »
Two part question:
1) How can I find a replacement depth sounder that will interface with the existing transducer from my deceased President LTD200?
2) If I replace the transducer, what is the path and where are the access points for fishing the transducer cable on a 1993 Carver 30-0 Aft-Cabin Motor Cruiser?
Michael Benner
The Black Rose
1993 Carver 300
mbenner1950@yahoo.com
Been thanked: 1792 times
Re: Depth Sounder Has Died
The data sentences used for the pre NMEA 2000 units were pretty standard among manufacturers. While it's likely that a sounder head of the same vintage would work, the challenge is finding one with the same pin configuration/plug. The trick here is ensuring that the problem is the head and not the ducer. Follow the current ducer cable or the shift and throttle cables from the engine compartment, they should give you an idea of where the race is that leads to the helm. Try eBay, you may find someone with the same unit for sale.
mbenner
Post by mbenner »
Thanks! I was able to find out from the manufacturer that the new unit would work with the old transducer which made the job much easier. I was also able to trace the raceway from the bridge through the salon which proved to be a pretty circuitous routing. It would not have been a fun job to snake the new cable as there were several 90 degree turns that would have made fishing more difficult.
In the end the installation was as simple and straightforward as I could have hoped for. I do appreciate your response and advice. I'm sure it will come in handy for the next challenge...or the one after that...
Michael Benner
The Black Rose
1993 Carver 300
Been thanked: 1313 times
What new unit did you get that paired up ?
mbenner
Post by mbenner »
I purchased a Hawkeye Depthtrax by Norcross Marine. It's a simple digital sounder with an alarm. That's all I needed. Bought it on Amazon.
Michael Benner
The Black Rose
1993 Carver 300
bptaylor
Vessel Info: 1989 3607
Post by bptaylor »
Hi Michael,
What type of depth sounder did you have previously? Was it a impulse QT-202 system? I need to replace my instrument gauge and possibly the thru-hall transducer component.
Brian Taylor
Brian.taylor049@gmail.com
