Chartplotter upgrade C70 to GO9
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 8 times
Re: Chartplotter upgrade C70 to GO9
Postby Carverlvr2 » December 31st, 2024, 12:49 pm
Thank you for that info! Since several of you have very similar boats to mine, what sort of amp hour draw do you see when your on the hook? With my two fridges, water/vacuflushes, and some lights, I’m expecting 10ah or less and I have a 300ah bank/150ah usable, so 15 hrs between genny runs?
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 119 times
Been thanked: 118 times
Postby KyleR » December 31st, 2024, 1:04 pm
We only have 1 refrigerator (the stock NovaKool) and have converted all lights to LED. We do not have an installed inverter.
We are full-time liveaboards and are on the hook probably 90% of the time, maybe more. Our average draw is 5ah from the house bank (200ah LiFePO4).
However, we also have a 3000 watt Jackery solar generator that we use for running the coffee maker, toaster oven, induction cooktop, charging phones/computers, etc. It will keep us pretty satisfied for at least 24-36 hours, depending on how much cooking we do.
So basically, we run our generator about once every 24-48 hours and only have to run it for about 2 hours to charge the Jackery, top off the house bank and get the hot water heater hot again for showers and such.
Now when it is 30F outside - or 90F, we run it alot more for HVAC!! ;-)
Hope that helps!
Kyle
MV Verity
2002 Carver 396
Carverlvr2
Postby Carverlvr2 » January 3rd, 2025, 8:09 pm
Kyle,
You’ve really got me thinking on that Jackery option. So you just plug shore power 1 into it and it runs the house accessories (stove, micro, coffee) when needed? Do you use the solar panel chargers or just charge off the genny when you run it? Do you shut off things like the boat battery chargers and water heater?
Has thanked: 270 times
Been thanked: 1157 times
Postby Midnightsun » January 4th, 2025, 5:11 am
Here is a little test I did on a Jackery 2000. I use it mostly for our 12v electric cooler fridge we keep in the cockpit. The nicest feature is the quick recharge as can be seen in my test, They do pack some serious juice. viewtopic.php?f=12&t=7575&p=59595&hilit=jackery#p59595
KyleR
2002 Carver 396
Postby KyleR » January 4th, 2025, 10:51 am
No, I don't run it to the shore power 1 connection, although you certainly could. However then we couldn't shut our salon door all the way (unless I left the unit outside) and there would be collateral drain from other non-essential loads unless I switched off the applicable breakers everytime. Too much hassle for me. :up:
Since the unit has four 120V outlets we just plug the coffee maker/toaster oven/etc. into it directly or via an extension cord (appropriately sized for the load of course ;-) ). We bought a single burner induction cooktop that works amazingly fast and uses a fraction of the power that a traditional heating element uses.
We use the solar panels as much as we can. When we were in the Keys last winter we had them out extensively. When we went north and it got more overcast and such we brought them in and put them away. They store pretty compact. But, in all fairness, the panels don't seem to put out the claimed output of 200watts each. The most I've ever seen is around 150watts per panel. Not bad, but not as good as the claim. Lots of factors impacting that and since I just lay them up on the bow I really have not worked to optimize their output.
But, as Hans wrote about in his thread, I can recharge the unit from nearly drained to full in just over 2 hours with the generator.
As a side note, one nice thing about being able to charge it this way is I can charge it off the boat if desired. When we passed through the Dismal Swamp earlier this year and spent the night at the free dock at the visitors center, the ladies in the visitors center let me bring the unit into their office and charge it up while me and my wife went for a walk. We came back to a fully charged Jackery and didn't have to run the generator that night. We've done similar at places we've stopped that don't have 30/50amp shore power but have a 110V outlet. Pretty cool. 8-)
Not necessary since we don't run it to the shore power Inlet. But if you did plug it in there, those would be loads you would definitely want to shut off as they have a big drain.
Kinda long-winded answer, but hope it helps!
Kyle
MV Verity
2002 Carver 396
Carverlvr2
Postby Carverlvr2 » January 20th, 2025, 9:10 pm
Thanks for all the input here. I’ve worked thru a few things and have decided to start with the BMV-712 gauge/shunt. I also know I have one of the three 100ah house batteries going out and the other two are 3yrs old now. Same with the two flooded starting batteries that the PO actually used deep cycles for. So the plan is to change all three banks to Duracell(sams) AGM’s and switch the OE charger to agm. The house bank will now actually give me the ah needed due to agm being able to drain 80% vs 50% on fla. The Victron shunt will let me monitor them and prevent discharging too far. Another plus is fresh batteries to start with a clean slate. Talking/typing it out with you all halped me connect the dots! Thanks!!
Users browsing this forum: No registered users and 9 guests
