Hour gauges
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 25 times
Re: Hour gauges
Post by Carverlvr2 »
My 2004 366 has similar issue. LCD on each gauge is nearly identical while the ecm’s show a 60 hr difference.
Been thanked: 1313 times
Re: Hour gauges
If I remember right the ECU data was actual engine running time and could be broken down further to idle hours and hours above certain rpm thresholds ....at least the mefi 4 we had was that way.
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Re: Hour gauges
Post by paulr »
Every boat I had the hour meters advanced from ignition pulses. Not from 12 volts only.
Been thanked: 1114 times
Re: Hour gauges
paulr wrote:QR_BBPOST Every boat I had the hour meters advanced from ignition pulses. Not from 12 volts only.
On my '83, the hour meter just ran on 12V fed from the port ignition switch.
I turned the port key on one time to check the fuel tanks but forgot to turn it off and found it the next day... about 14 hrs later and there were 14 more hours on the "clock".
paulr
Re: Hour gauges
Post by paulr »
Well, if you wanted to syncronize it just diconnect it for 14 hours.
My boat is a 2001 but it had new 8.1 Crusaders engines installed in 2008. The dashboard instrument read 800 something but the ECM's read around 510.
Are there any modern day tach/hour meters that would syncronize with the ECM?
