Hot Water Heater Leak
Ssmullugan
Vessel Info: 2000 Carver 326 aft cabin
Has thanked: 3 times
Post by Ssmullugan »
We have a 326 aft cabin (new to us) and having a plumbing issue. Heard a “pop” last night, then water pump is runni g continuously. No water pressure. Shut everything down. Found water around hot water heater and can hear a drip if we run the water pump for a minute. Carpeton floor in cabin is wet-below hot water heater. Sumps are all good.
Thoughts?
Been thanked: 1313 times
Re: Hot Water Heater Leak
Welcome to the forum.......possible pressure relief valve on tank let go and maybe is now stuck open, hopefully you shut off the power to the heater quickly to save the element.If so easy fix.......good luck......
Ssmullugan
Thanks for the reply.... think we actually blew a hole in the water heater.... water seeping from bottom. Going to order a new one and install. Pretty easy access. We will keep posted in results
Ssmullugan
Good news- Got the old hot water heater out, replacement in.working like a charm!
Been thanked: 248 times
Post by mjk1040 »
Great! :beergood: Welcome Aboard!
