AC Replacement
Peter3607
Vessel Info: 1998 Carver 500 CMY
1989 Carver 3607 Aft Cabin
Has thanked: 29 times
Been thanked: 2 times
AC Replacement
Post by Peter3607 »
Anyone know where I can find a replacement for a Marine Air VR6K-H (6,000BTU) unit? May have to replace the unit if it cannot be repaired. The unit runs fine but it doesn't pump out the cold air. Hoping to get an AC guy to have a look but keeping my options open at this time.
Unit is tucked in the port aft corner of the master cabin and very difficult to access. Seems like Carver built the boat around the AC unit!! I guess they never had service in mind during their planning off placement.
Thoughts??
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: AC Replacement
Post by Tireless »
Remove the unit and take it to Bob at Northland Supply in Keswick. He will bench test it, fix or rebuild if required. Call him and tell him what’s going on and he may have an answer for you. 905-478-2244. He can also send a tech to your boat. Highly recommend him.
Greg
Been thanked: 1792 times
Re: AC Replacement
Bob is definitely the go to guy, hard to beat his knowledge, however IMO, his appliances and parts are overpriced. If the unit is defective and original to the boat, I wouldn't put any money into it because you'll likely spend a fair bit of money and still have a 30 year old unit that's likely to have something else fail at any time. Newer units are more efficient, use less power, are much quieter, are likely to take up less space, and will come with a digital control panel.
I'm assuming you've confirmed that the raw water pump is pumping and discharging overboard? How many AC units on board? Does either mode work; heat or cooling?
Re: AC Replacement
Post by Midnightsun »
I may be able to help out here as I have the original 6,000 btu unit from my 2007 master bedroom laying around which is fully functional. $100 for my troubles and shipping at cost and it's yours. Don't think I still have the thermostat though. Shipping from QC to ON cannot be all that much then again shipping time with covid may take several years. :lol: Will take a picture when I get to the office tomorrow as today I finally get to go see the boat. :-D :-D
Peter3607
Re: AC Replacement
Post by Peter3607 »
Viper wrote:QR_BBPOST Bob is definitely the go to guy, hard to beat his knowledge, however IMO, his appliances and parts are overpriced. If the unit is defective and original to the boat, I wouldn't put any money into it because you'll likely spend a fair bit of money and still have a 30 year old unit that's likely to have something else fail at any time. Newer units are more efficient, use less power, are much quieter, are likely to take up less space, and will come with a digital control panel.
Yes raw water pump functions and discharges overboard. Heating appears to work although I've only tested it in the summer lol. I have a total of 3 units on board. 2 are working great. figures the one in the master cabin doesn't
Been thanked: 1115 times
Re: AC Replacement
Peter, I'm wondering if you can provide a few more pictures of the install back there. I am almost done retrofitting my 3607 with HVAC as it never was equipped with it and am curious what other installations look like, especially the ducting.
Peter3607
Re: AC Replacement
Post by Peter3607 »
km1125 wrote:QR_BBPOST Peter, I'm wondering if you can provide a few more pictures of the install back there. I am almost done retrofitting my 3607 with HVAC as it never was equipped with it and am curious what other installations look like, especially the ducting.
I do have some pictures however I cannot attach them to this message for some strange reason. The forum doesn't recognize the pictures to attach. If you can provide your email I can forward them to you separately.
