AC water pump/ strainer and valve location ?
REPOSE
Vessel Info: 1988 Carver 2827 Voyager
Post by REPOSE »
Just put my new to me Carver 2827 Voyager in the slip yesterday , having trouble finding the thru hull connection and pump. There is no water flow through the unit and there for is not cooling. Thank you in advance for your help.
dtcom
Vessel Info: 1993 Mariner 330
Has thanked: 4 times
Been thanked: 3 times
Re: AC water pump/ strainer and valve location ?
Post by dtcom »
REPOSE wrote:QR_BBPOST Just put my new to me Carver 2827 Voyager in the slip yesterday , having trouble finding the thru hull connection and pump. There is no water flow through the unit and there for is not cooling. Thank you in advance for your help.
I don't know if this helps, but I have a Mariner 330. The thru hull is just outside the head, starboard side. There are 2 hatches outside the head to remove.
The filter on mine is a glass canister on the port side. Every time I have put the boat in, the filter needs to be cleaned.
Do you hear the pump running?
Been thanked: 1313 times
Welcome to the forum.....where is your AC unit located on that boat ?
