396 Carver forward Air conditioner Control Box location?
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 33 times
- Been thanked: 19 times
My 2001 396 Carver has 3 air conditioners. The compressor does not start when calling for heat or cooling on the forward unit but the fan does run ok. The passport II thermostat shows its calling for heat or cool.
The A/C repair guy showed up and needed to get to the Control Box box. We found the pump relay box in the forward bildge bout no Control Box. Can somebody please tell me where it may be located.
Thank you for any comments
- Been thanked: 615 times
Re: 396 Carver forward Air conditioner Control Box location?
- paulr
On my next visit (93 mile ride) I'll pull out the duct and see if its under there.
- paulr
- paulr
The problem was the control board relay. The printed circuit side of the board had a burn mark on one of the soldered pins of the relay. I got a replacement board and the unit worked fine. But__________ one week the compressor burned out.
Bought a new Dometic 16000 BTU from West Marine, I will install it 7/14/24.
Users browsing this forum: No registered users and 92 guests
