Solar System
cyclebender
Vessel Info: 1987 Carver 32 Mariner
Solar System
Post by cyclebender »
I am in the process of adding a 30 watt solar system on my boat. I intend to connect the output from the system to the house batteries. Should I disconnect the battery charger from the batteries, or just turn the charger off? Does it make any difference?
Thanks for any advice
Been thanked: 248 times
Re: Solar System
Post by mjk1040 »
I would venture to guess it depends on the charger. If you have a smart charger it should be no problem, otherwise you may boil them over! Mike
Re: Solar System
Post by g36 »
Do you mean 300 watt per chance instead of only 30watts? If so maybe you post what you are installing for some other interested carver boaters happy new year
Re: Solar System
I guess the question is what are your intentions for the solar panel? Is it to charge your bank while at the dock? If so, why? Why the panel instead of the on-board charger? If the panel is for charging while at anchor, then that makes sense. Having said that, if you don't have a smart on-board charger, you may be better off with the panel doing the charging during the week as long as the panel's charge controller is a smart one.
Re: Solar System
Post by g36 »
30 watts is only 2.5amps in a perfect solar world, wont get that in real life usage. hoping he means 300 if trying to charge batteries
