Midnightsun wrote:QR_BBPOST Mine is a 2007 so I would assume similarly wired. The switch under the stairs allow for A/B selection. Arch mounted antenna or dockside cable. Maybe you already have it? Under the protective cover where your shore power is you may have one marked telephone/cable.
You were spot on, that's our setup!
I think PO had disconnected both TVS due to installing larger flat panel TVs on articulating mounts. We will be hooking up and checking out next visit.
**update**
turns out our Shakespeare 3015 SeaWatch Marine TV Antenna selection switch under the salon stairs, is bad. Connected inlet coax directly to comcast/xfinity cable box, and all was good.
now using 1byOne flat panel antenna's on both TV's for improved reception, with salon TV using HDMI-1 cable box input (wife/Captain) loves that!
Our salon clarion dvd player refuses to work, so a Sanyo BlueRay player from walmart $48, was added to salon on HDMI-2, all ready for the summer over nights now!
