2003 360ss shore power ground fault issue
Re: 2003 360ss shore power ground fault issue
in many of these boats the neutral wires (white) and the grounds (green) are on a common bus bar at the breaker panel. A GFCI measures the current from the hot to the neutral and any difference it will trip. So, if your neutrals are intermingled between two shore power inlets (very common), or a ground and a neutral are on the same screw somewhere it will trip the shore power gfci.
This can be a PIA to find and fix, but it can be done. Lots of time, but usually not much $ for materials.
I have what I call my travel cord stored under the hatch in the cockpit which only gets used when transient docking along with my travel hose. My dock cord and city water hose are fixed to the dock and remain there all season long except if we leave for a few weeks vacationing on the boat where I remove the hose and shore power cord which get stored in my car trunk until we return. Also do the same for my fenders, 3 big ones tied to the side of the dock with soft fender covers on them, these stay there all season long even when we are out for extended periods. This way we do not need to deploy/store fenders every time we go out and come back.
- Been thanked: 1313 times
A little extra info.....Should be a sticky IMOBaby Lentz Crewz wrote:QR_BBPOSTWe do have a reverse polarity light system and those are fine. The surveyor tested for that when we were buying the boat at that checked out. We have power leaching from the boat to the shore power.
https://www.proboat.com/2011/10/demysti ... onnection/
- Baby Lentz Crewz
- Vessel Info: 2003 Carver 360 SS
- Been thanked: 2 times
There is a cabinet in the back of the boat.
- Baby Lentz Crewz
I wish it were possible to do as you suggest but the boat end is hard wired into the panel inside the boatMidnightsun wrote:QR_BBPOSTI have what I call my travel cord stored under the hatch in the cockpit which only gets used when transient docking along with my travel hose. My dock cord and city water hose are fixed to the dock and remain there all season long except if we leave for a few weeks vacationing on the boat where I remove the hose and shore power cord which get stored in my car trunk until we return. Also do the same for my fenders, 3 big ones tied to the side of the dock with soft fender covers on them, these stay there all season long even when we are out for extended periods. This way we do not need to deploy/store fenders every time we go out and come back.
Hmmm, learn something new every day. Never saw a hardwired setup unless it was equipped with a Glendinning cable master.
- Baby Lentz Crewz
We seem to have found the culprit. The ice maker was trying it. Even when the breaker was off. It was coming through the common.bud37 wrote:QR_BBPOST The leakage could be coming from any appliance, battery charger etc....don't just focus on the shore power cord unless it is in the water. Your boat is probably just above the threshold for your marina but below some others. Very difficult and time consuming to find these sorts of things.
Good stuff....glad to see you took the time to sort it out......many would have just blamed the dock service. Actually you may have saved a life here......Baby Lentz Crewz wrote:QR_BBPOSTWe seem to have found the culprit. The ice maker was trying it. Even when the breaker was off. It was coming through the common.bud37 wrote:QR_BBPOST The leakage could be coming from any appliance, battery charger etc....don't just focus on the shore power cord unless it is in the water. Your boat is probably just above the threshold for your marina but below some others. Very difficult and time consuming to find these sorts of things.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Was it an AC/DC ice maker? My fridge created the same situation for me, through the AC to DC power unit on the fridge. When it failed, a small amount of AC leaked back through the ground.Baby Lentz Crewz wrote:QR_BBPOSTWe seem to have found the culprit. The ice maker was trying it. Even when the breaker was off. It was coming through the common.bud37 wrote:QR_BBPOST The leakage could be coming from any appliance, battery charger etc....don't just focus on the shore power cord unless it is in the water. Your boat is probably just above the threshold for your marina but below some others. Very difficult and time consuming to find these sorts of things.
