Warning lights above ignition switches?
Posted: June 3rd, 2020, 3:29 am
by BarryK
Hi all,
I tried to look this up in the owner's manual but could not find out what these lights are for. They have never turned on.
I just had a false alarm from a failed oil pressure switch so I am familiar with the engine buzzer circuit.
Thanks,
Barry
Re: Warning lights above ignition switches?
Posted: June 3rd, 2020, 6:57 am
Directly about the ignition switches as in the photo are breakers not light, they are for the ignition circuit. The warning lights to the right are for your Walter V-Drives. They should come on when you start the engines but go out when a certain pressure is achieved after 1200 rpm. If they don't go out, there is a problem.
Posted: June 3rd, 2020, 9:35 am
As Viper says.....if you look real close they have a soft cover with the white button you see underneath.
Posted: June 3rd, 2020, 1:14 pm
by BarryK
That makes sense, I see they are breaker buttons now!
Yes, the V drive lights are working properly, they go out above 1200 rpm.
The engine warning buzzer was going off on the port engine. It was due to a failed oil pressure sensing switch. I replaced it and all is well now. I got a quick lesson on maneuvering with one engine. We should all practice that more often.
Thank you!
