Shore Power Cord(s)
Posted: January 30th, 2025, 4:19 pm
by wsp2
My 1995 440 aft cabin has two 50A power inlets. When I bought the boat it came with two long 50A cords which then go into a splitter, and I plug this splitter into a single 50A shore outlet. This has worked fine so I don't think I really have the need to plug into two 50A shore outlets.
We're cruising so each marina is different, but I was thinking about buying an extension since there have been a few times our cords wouldn't reach. Since we normally use only a single 50A outlet, is there a problem with buying a single long 50A cord and have a splitter on the boat end instead of on the shore power end? This would be much easier to deal with instead of hassling with two long 50A cords. Depending on the length I was thinking I could have a single 50A extension just in case.
Re: Shore Power Cord(s)
Posted: January 30th, 2025, 6:52 pm
by Midnightsun
Need more info. Since you have 2 50a cords, I assume they are of the 125v variety, correct?
Posted: January 30th, 2025, 7:55 pm
by wsp2
I believe they are 125/250v cords. There are 2 hooked prongs and one straight prong.
Posted: January 30th, 2025, 8:19 pm
by Midnightsun
2 hooked prongs does confirm 125/250. ;-)
Using a single cord and a Y adapter at the boat will work fine as long as you draw does not exceed 50a. The other end would simply be plugged into a 125/250 shore power pedestal.
You may want to also get a reverse Y adapter as many marinas do not offer 50a at the pedestal and therefor you can plug into dual 30a outlets which opens up several more docks where you can dock your boat when transiting.
They are spendy but well worth it. Can usually pick a used one up one eBay for much cheaper. https://www.ebay.com/itm/135510346392?_ ... R5TN5Z6XZQ
