Bilge Blower switch
Jet Lag Tiki
Vessel Info: 1999 Carver 350 Mariner
Bilge Blower switch
Post by Jet Lag Tiki »
Hello!
I have a 1999 Carver 350 that we bought last fall. The Bilge Blower switch, which is an illuminated rotary knob, stopped turning the blower off. The little green light on the knob still works if I turn it right to on, and the blower runs continuously whether the switch is on or off. If I turn the knob to the OFF position, light goes out but the blowers continues to run: I turn it off inside on the Main panel with the breaker.
The marina is ordering me a new rotary switch, but has said they found out I have to buy the switch for $35 AND the Illumination Module for another $25. I asked ChatGPT about that and was told if the light is working, the illumination module is working, and I only need the switch.
Anyone had this or have an answer?
Kevin
Been thanked: 1117 times
Re: Bilge Blower switch
I don't know that model specifically, or that switch, but if the light goes on and off with the switch position that it might NOT be the switch! Do you know if that model uses relays for the blowers?
