SeaDek on my 466 swim patform
Been thanked: 470 times
Re: SeaDek on my 466 swim patform
Post by RGrew176 »
Nice looking addition.
Blu789
Vessel Info: Carver 355 Aft Cabin 1998
Post by Blu789 »
I am wanting to get this done on my swim platform, stairs, and aft cockpit. $2400 seems a little high for that. Does anyone know if there are reasonable places in Cincy OH to have this done?
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Post by vineyardgray »
Looks very well done.
I always wonder about the existing anti skid - do they sand it down or grind it before applying the foam?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
dkoons16
Has thanked: 10 times
Post by dkoons16 »
Looks great!!!!
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Post by Cliffm »
Looks Awesome! thanks for posting
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Post by ColRon »
vineyardgray wrote:QR_BBPOST Looks very well done.
When I had Seadek installed on my swim platform, they just cleaned it with some strong cleaner to remove any wax and any other contaminates that might prevent a good bond to the surface.
Ron
“Escape Plan”
Murray, KY
:usa:
Has thanked: 605 times
Been thanked: 1313 times
I have a question....what happens when it rains, does that sea deck soak up water or does the water sit on the surface then dry quickly.
Post by tomschauer »
That looks great!
Does anyone who has had the sea deck for a few years have pics of how well it holds its good looks?
Been thanked: 1792 times
I posted on a thread a couple of years ago about the expected condition after a few years of wear and tear. I have regular access to a boat that had it professionally installed back then. At that time, I read as much as I could and noted the condition of the product on a lot of small boats that came with it from factory. The consensus back then was that there was about a seven year life expectancy before its condition started getting to a point where it would be evident that replacement would be required within the following couple of years.
I can tell you from what I've seen so far that the adhesive eventually starts to fail causing the product to separate. The edges start lifting first, and over time, small chunks of the edges start chipping/tearing off resulting in very uneven lines. Considering the overall install is made up of several sections/blocks that make a grid, there are a lot of edges that really stand out with this wear. It should be noted that there was an installation advantage on the vessel I have regular access to in that there was no non-skid as it had been removed for a swim platform core repair. The flat surface should have been the adhesive's best shot of keeping the product in place but that's not the case. When non-skid is present, it usually doesn't get removed and contributes to the product lifting prematurely.
I also mentioned that the non-skid keeps the product lifted above the true surface and eventually allows water ingress around the edges. This water will migrate throughout the mating surface and stay there for a long time. This may be what eventually causes the adhesive to fail in the middle sections over time. With water under the product, one has to wonder if frost also contributes to lifting the product. Some installers will apply caulking around all edges to help keep it water tight however the caulked seem usually fails as the foam eventually starts shrinking slightly over time and separating from the caulking.
This particular boat gets a lot of use with adults and kids though no pets are involved on this one. I've heard of warnings if you have dogs on board regularly, especially if they have long nails as that will tear up the foam. The condition of the main body of the product still looks great and the colour has maintained its original look after all this time. This particular application is a teak coloured plank look and from a distance looks awesome but the wear around the edges of every panel is very evident as you get closer.
There's other pros and cons but overall, it's a good product. It doesn't seem to retain water within the foam itself which is important, and it keeps it's colour for a long time. I'm due to replace my carpet on the aft deck and around the helm but can't decide whether to replace with carpet again or install a permanent covering such as Seadek. Will have to continue pondering that over a few more beers :beergood:
