Backup Fuel Level Indication
- Pura Vida
- Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
- Has thanked: 17 times
- Been thanked: 7 times
Still unhappy with less-than-certain fuel levels, i came up with a cool solution. I will try to post pictures.
-painter's masking tape
-standard 2-part epoxy, clear, ~ 30 min working time
-approx 1 gram of thermochromatic pigment. My selection changes from black to yellow @ 88F/31C. (bought 10 gram container, but only used a tiny amount.
On each of my two aluminum fuel tanks, I laid vertical masking tape ~ 1" spaced. Mixed the pigment into the 2-part epoxy. Painted between the tape. Removed the tape to leave a 1-inch wide strip of pigmented epoxy.
After curing, i now have a black strip on each tank. I spray hot water on the tank for ~ 15 seconds until the epoxy turns yellow. A few seconds later, since the fuel is cooler, the fuel level quickly turns black again showing the fuel level.
My stbd engine heats the hot water tank, and with the cockpit shower, this is quick and easy. Doesn't even take much water - maybe 1 quart (which goes to the bilge).
I think i was able to post pics of the pigment (amazon), and the resulting color changes after hot water. Seems they may be rotated and out of order, but still useful.
If someone were to try this, i think my temperature selection was good for my area, maybe warmer climates may need higher activation temperatures. I bought the 10 gram size, probably enough for 50 tanks...although it is cool and you can find other uses for it, certainly don't need the 10 gram size.
- Pura Vida
Re: Backup Fuel Level Indication
- Has thanked: 455 times
- Been thanked: 1671 times
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 15 times
- Been thanked: 36 times
- Has thanked: 324 times
- Been thanked: 595 times
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 21 times
One other fuel tank level test that I trust is simply open a access plug on the top of my tank and insert a 1/4" wood dowel rod from the hardware store. I will always trust my dowel rod over my gauges.
