Hello - hoping someone here found a solution for replacing the plastic panels that slide into the tracks to close the walkthrough.
Carver Santego 380 Walkthrough Panels
- Santego2000
- Vessel Info: 2000 Carver Santego 380
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Carver Santego 380 Walkthrough Panels
Welcome aboard! My guess is that you will have to have someone custom make them. Luckily, I still have mine, I'm missing the glass fairing (for lack of a better term) section.
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- Been thanked: 1114 times
Looks like they're slightly curved.
However, I think you could make some out of Starboard if you couldn't find the real ones. The only trick would be forming them over some type of a "mold". I made some forms out of scraps of wood then then heated Corian in my oven and dropped them on the forms. Worked perfectly.
Your pieces might be too large to fit in a conventional oven, but you might be able to rig something with some high wattage lights.
- JimN
- Vessel Info: '89 Carver Santego 38
- Been thanked: 3 times
Starboard (and many other plastic panels like Marine Board (which is basically the same thing, with a different name- it's all UHPE) can be formed using heat. If you call a supplier or the manufacturer, search online or watch videos on YouTube, you'll find the info you need WRT temperature used for forming shapes. IIRC, less than 300°F and time to conform is about right.
You could make them from Fiberglass, too. www.boatworkstoday.com has at least one video showing him making a hatch cover and it would be done in a similar way, using thin bending plywood and wooden pieces that have been cut to match the curve, glued to the backside of the form. He used particle board with a Melamine surface and it's available in 1/4" thickness, but I think I would go to a big box store and buy a small sheet of laminate, use contact cement to attach it to the curved panel (to prevent the resin from sticking) and by making it longer than you need, you can cut it to fit.
