36 AftMY. Ready to Reupholster Dinnette and cannot get top rail cushions off. Any suggestions that don’t include full demolition.
To our best determination, there are no metal bracket hangers and overhang board seems to be nailed from below to corner shelf. Which is also screwed down and not really accessible.
How to Remove Dinnette back cushion
- MCADRG
- Vessel Info: 1991 3608 Aft Cabin
Twin 454 Crusaders Gas - Location: Sarnia, Ontario
- Has thanked: 1 time
- Been thanked: 2 times
Re: How to Remove Dinnette back cushion
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Check to see if you have any anchoring screws buried in the carpeting. On the steps that go down into my aft cabin, that’s how they are secured.
- Been thanked: 1114 times
Is it possible that whole "module" comes out as one piece? Could there be screws inside that access panel that screw into the base from below (and then perhaps a few in the cabinet in the head, going through the bulkhead)?
- MCADRG
Figured it out….
The top rails are on plastic ’christmas tree’ plugs. Needed to pry straight up and off. Was lucky and able to snap back down on originals when upholstery job was done.
