Page 1 of 2
New CAR ER Owners ... need a V
Posted: March 14th, 2016, 9:30 am
by TonyC
Looking for a missing V replacement. Note top right corner of pic. On a 1998 350 Mariner. Approximately 2" raised black vinyl. Any ideas as to where to obtain a replacement will be appreciated. Thanks!
Re: New CAR ER Owners ... need a V
Posted: March 14th, 2016, 10:21 am
by SplashyLady
Contact these folks and see what they have:
http://stores.ebay.com/MK345-123?_trksid=p2047675.l2563
Also Great Lakes Skipper has a lot of OEM Carver stuff:
http://greatlakesskipper.com/
Good luck!
Posted: March 14th, 2016, 3:19 pm
by TonyC
SplashyLady wrote:Source of the post Contact these folks and see what they have:
Good luck!
Thanks for the suggestions! I did try Great Lakes Skipper without luck. Will check out the ebay site.
Posted: March 14th, 2016, 5:03 pm
by Lyndon670
Another idea is to remove the entire badge with a heat gun. Go to your local sign shop with a picture and have them cut a 3D vinyl decal. Way cheaper, no fade and easily replaceable.
Posted: March 14th, 2016, 10:01 pm
Have you tried calling Carver direct or a local dealer?
Posted: March 15th, 2016, 8:58 am
by TonyC
Lyndon670 wrote:Source of the post Another idea is to remove the entire badge with a heat gun. Go to your local sign shop with a picture and have them cut a 3D vinyl decal. Way cheaper, no fade and easily replaceable.
Thanks Lydon ... a good back-up idea.
Posted: March 15th, 2016, 8:59 am
by TonyC
Viper wrote:Source of the post Have you tried calling Carver direct or a local dealer?
Hum ... Now why didn't I think of that? Thanks Viper, I call today.
Posted: March 15th, 2016, 11:14 am
by SplashyLady
Don't use a heat gun - here's a trick the body shops all use - dental floss! Just work dental floss back and forth under the letters until they release. There may be a bit of adhesive left, but GooGone will take care of it. Less chance of damage to the fiberglass or paint with floss compared to the heat gun. :down:
Posted: March 15th, 2016, 6:14 pm
...Don't use a heat gun....
Agreed. Unless you’ve done it before or given some forethought about how to use the heat gun for this type of work and the damage it can do if done wrong, you’ll be calling for a gel repair. Seen it happen many times. It’s doable, you just need to be careful and aware.
Posted: March 16th, 2016, 12:17 am
by Lyndon670
Good point Re heat gun - I should have specified "experience....forgot alot of newbies here....
