83’ 3396 window removal to rebed
Posted: June 12th, 2020, 4:41 pm
by Jphill85
Trying to remove the port side windows in the cabin to rebed them. Any tips and tricks? It’s been a pain so far.
Re: 83’ 3396 window removal to rebed
Posted: June 21st, 2020, 9:44 pm
by quickdecision
JPhil
Are you pulling just the glass or the entire aluminum frame? Do you know how to remove the glass?
Ron
Posted: June 22nd, 2020, 5:19 am
by tonyiiiafl
I have a 390 and would like to hear how to remove the glass so I can replace the cat whiskers.
Posted: June 22nd, 2020, 9:36 am
by chpsk8
tonyiiiafl wrote:Source of the post I have a 390 and would like to hear how to remove the glass so I can replace the cat whiskers.
You shouldn't have to pull the windows to replace the schlagle. There's an alternative that snaps into the track.
https://www.dkhardware.com/search?keyword=CRL+Z78295C+Zipper+Pile+Weatherstrip
Posted: June 22nd, 2020, 11:26 am
chpsk8 wrote:Source of the post
I just did this on a couple of my windows. When you start pulling the old stuff out, it slides along the track. Snap the new stuff in a few inches at a time and slide back into place sliding alongside the window until it gets all the way to the end of the frame.
I was surprised at how much dirt and "gunk" was packed underneath the old whiskers/pile. It took some scrubbing to get all that out but the drains now work significantly better than before - no wonder!!
Posted: June 22nd, 2020, 4:29 pm
km1125 wrote:Source of the post I was surprised at how much dirt and "gunk" was packed underneath the old whiskers/pile. It took some scrubbing to get all that out but the drains now work significantly better than before - no wonder!!
Clogged/dirty drains is one of the major reasons for leaking windows.....good catch.
Posted: August 16th, 2022, 10:12 pm
by beancounter
I just redid my windows that were leaking like niagara falls when it rained. I only had to do starboard side. It took me two weeks but I only had a few hours each weekend so daily it could have been a weekend project. The entire board under the window was rotted away. We removed the outer trim in the salon and then used a multi-tool to cut out all the bad wood. We had mag. cut for the two pieces of rotten wood. We sealed everything with a petit wood sealer. then we used 4400 and installed both pieces. After that we screwed everything back in dealing with 4400 a we go. It’s been a raining summer and we have stayed bone dry.
Posted: August 17th, 2022, 5:06 am
by Phrancus
So do I understand correctly that the windows are sandwiched between an inner and an outer aluminum frame. And that you need to remove the frame to take the windows out?
I have the choice to scratch the small crack between frame and hull and then caulk it up. But if taking the farme out is do-able, then I could caulk it up correctly.
Although I'd probably unearth a whole new snake pit of neglected work.....
