New member and just got a mariner 360 2004
DrSleep
Vessel Info: 2004 Mariner 360
Post by DrSleep »
Looks like I will have a lot of questions
1. When the boat is on shore Power the AC’s are working BUT when of shore and generator works I can’t turn them on. Any help? Thanks
Been thanked: 1792 times
Re: New member and just got a mariner 360 2004
Congratulations on your new acquisition, and welcome aboard. I'm sure other Mariner owners will chime in but I suspect the switching relay for the AC line (line 2) has failed. There are relays typically behind the electrical panel that automatically switch the source power from shore to generator when you turn the generator on. You can usually hear them when they activate. I'm assuming that everything else works and that you have two shore power lines?
Been thanked: 1313 times
Welcome to the forum.....on the top back of the generator should be a black box, on the side is a breaker switch, some fuses and the a start toggle, make sure the breaker is in the on position to get power to the boat from the gen. The gen can be started and stopped from there and run without sending power to the boat.
Has thanked: 70 times
Been thanked: 493 times
Post by waybomb »
Welcome aboard!
