Have a 2001 356 aft-cabin. Do I need to have zincs on my tabs ?
Where is the Galvonic Isolator ?
Isolator and Zincs
- Been thanked: 654 times
Re: Isolator and Zincs
I'm in freshwater with a 97 405. I don't have any sacrificial anodes on my trim tabs. Where are you boating?
- Been thanked: 1792 times
If you have a galvanic isolator, they're often mounted behind the breaker panel. It's not a requirement to have anodes on your tabs but it is an option. What do you currently have for anodes?
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
I boat in fresh water and I do have anodes on my trim tabs. They are mounted on the top side of the tab.
Greg
Greg
- Been thanked: 1313 times
You should have 2 galvanic isolators, one for each shore power line, wired in the green ground....they are most likely behind the 120vac panel. Depends on where your boat is, we always had anodes on the tabs, the shafts and a divers dream on the transom.
Where do you boat ....fresh water or salt ?
- V12diablo
- Vessel Info: 2001 Carver 356 Aft Cabin
- Has thanked: 1 time
- Been thanked: 13 times
On my 2001 356, it is located in the master birth behind the right head board, I do have zincs on my tabs and I am in freshwater.
Jason
Jason
- seaweed
- Vessel Info: 2001 Carver 356 AC
- Been thanked: 3 times
I'm in fresh water and on my 2001 Carver 356 Aft Cabin, I have magnesium anodes on the shafts, tabs and hull.
Use zinc for salt water.
