1997 310 Santego Owner Looking For Parts
Jfraser419
Vessel Info: 1997 Carver 310 Santego
Postby Jfraser419 » March 3rd, 2025, 11:31 am
attachments (1).zip
Hi All,
I've owned by 310 Santego in Chicago for 10 years. I was down doing some prep for the season and noticed the straps from the lift from storage had broken the fittings on the bilge drain on the hull of the boat. Both sides. I've attached pics of both as well as some other parts I'm trying to source. From my research here, it appears part numbers are not really helpful with Carver closing operations. Does anyone have any suggestions on where to source these types of parts? Bilge drain covers, window vents, battery door latches, etc?
Thanks for any help!
Jon
Has thanked: 54 times
Been thanked: 438 times
Re: 1997 310 Santego Owner Looking For Parts
Postby waybomb » March 3rd, 2025, 12:27 pm
Welcome aboard!
Drive north to Kendor's in Franklin Wisconsin. Just over the border
It's a big boating supply store selling new and surplus goods. Was a great place to find surplus Carver stuff while Carver was still in business. But they have quite the inventory.
They also have an online store - Great Lakes Skipper.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 396 times
Postby Cooler » March 4th, 2025, 11:46 am
Yep. That's the place. If you go there, plan on spending more time looking at boat stuff. The fittings you show are common fittings. Any marine store should have them. Just measure each one to make sure you get the correct size. They do dry out and snap off every once in a while. Easy replace process, as long as you can access them. Good luck. 8-) er
Cooler By The Lake
Users browsing this forum: No registered users and 75 guests
