Cleaning your Motors
golgi
Vessel Info: Carver 530 Voyager Pilothouse
Has thanked: 19 times
Been thanked: 6 times
Postby golgi » September 12th, 2019, 10:20 am
I'm curious what process or strategy you guys use to clean your motors. I need to do a deep clean on my Volvo TAMD74-P EDC's before touching up the paint. My plan is:
Cover EDC with plastic shower cap
Spray motor liberally with degreaser
Use a soft brush and warm water containing Dawn
Rinse with mist from garden hose sprayer
Shop vac any standing water immediately
Allow to air dry
Any one see a problem with this or have a better idea?
Thanks!
Alaska 530 Voyager
Has thanked: 42 times
Been thanked: 33 times
Re: Cleaning your Motors
Postby Alaska 530 Voyager » September 12th, 2019, 1:01 pm
I just did the same thing. If you search you can see my pictures I posted under "engine room makeover". I actually ended up painting over the dirty motors for the most part. Cleaning became too tedious. I had tried several different cleaners and degreasers. I believe that Simple Green worked the best. I used tinfoil to wrap hoses and cables and harnesses before I painted. I definitely recommend using the tinfoil, it worked fantastic. Good luck, Dave.
golgi
Postby golgi » September 12th, 2019, 3:58 pm
That's phenomenal! How hard was the bilge painting or did it clean up that well? I will definitely be using the aluminum foil trick!
Alaska 530 Voyager
Postby Alaska 530 Voyager » September 12th, 2019, 5:53 pm
I used the same paint on everything. It covers perfectly. I just made sure to wipe off any wet oil from the motors and just wiped the bilge area with a dry rag. I'll attach a pic of the paint I used. I brushed everything, no spraying.
golgi
Postby golgi » September 12th, 2019, 7:09 pm
Thanks! I already purchased the Volvo Penta paint so I'll probably still spray the motors out. But I think I'll consider this for the bilges!
Users browsing this forum: No registered users and 104 guests
