Fuel transfer line
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 415 times
Re: Fuel transfer line
Post by Cooler »
Here is what should appear in your owner's manual. Should be about section 5.------- 8-) er
Because the generator draws fuel only from the starboard fuel tank, the fuel
levels in the tanks may become unequal. If this occurs, open the fuel equalization valves, located on the bottom near the aft center of each tank. When
the fuel levels are equal, close the valves.
Always close both fuel equalization valves when you are not equalizing
the fuel levels in the fuel tanks. If one of the valves developed a leak while
open and unattended, fuel could spill into the engine room undetected,
creating a hazardous condition
Cooler By The Lake
vtcats
Vessel Info: 2006 46 Voyager
Volvo D9-500’s
Has thanked: 2 times
Been thanked: 5 times
Post by vtcats »
Which brought me to my original question, if the boat has a slight list (as many boats do), do they still equalize. Which I believe was answered, as in, no. They level would be a better description. The helpful irony is, while the genset draws from the starboard tank, my port engine burns at a slightly higher rate than the starboard.
2006 46 Voyager
Mallets Bay, VT
Been thanked: 1792 times
If the boat has a list, the tank on the listed (lower) side would have the most fuel when equalized. This will cause the hull to list even further if it's enough fuel to make a difference.
BTW, it wouldn't be that big a deal to install a transfer pump, then you can control which way you want the fuel to go. The hardest part would be running the wiring.
vtcats
Volvo D9-500’s
Post by vtcats »
Viper wrote:QR_BBPOST If the boat has a list, the tank on the listed (lower) side would have the most fuel when equalized. This will cause the hull to list even further if it's enough fuel to make a difference.
Agreed
2006 46 Voyager
Mallets Bay, VT
