Aft deck plastic panels
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
Re: Aft deck plastic panels
Mine were attached with what appeared to be 5200 or similar product. I think I used a solvent to soften it up then a razor, a knife blade and a flat tip screwdriver to get it out of the groove once separated. It was a pain in the A$@!
- Vessel Info: 1991 Carver 33' wide body aft cabin model 3330 twin 330hp Volvo's
- Been thanked: 2 times
- Wayne162
- Captain
- Contact:
- 1992330aftcabin
- Vessel Info: 1992 330 Carver aft cabin
- Has thanked: 54 times
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Wayne162 wrote:If you are looking to do it yourself if the parts are not available from Carver, try Mcmaster-Carr. I purchased a 4' x 8' sheet of UV protected acrylic panel that I cut for a snow plow blade insert. They are on line and supply bulk composite material in whatever size you specify. My sheet ran about $80.00.
I just looked on their site. $214 for a 4’x8’ sheet of 1/4”. No quote on delivery yet.
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Bentone23
- Contact:
KEND wrote:I also have two cracked panels for my 1991 33 aft, My problem is I cannot get the corner piece off the plexiglas panels on either side, so without separating the plexiglas I cannot use the corners. They seem to be locked on, maybe glued, not sure , all I know is no matter what, I have even tried to separate them using a razor knife to scrap inside the edges. No matter what I try no luck, any suggestions ?
Shatter the plastic out with a chisel.
1996 355 Aft Cabin
Central California
- Wayne162
- Captain
- Contact:
- Glassman
Return to “Boat Parts For Sale”
