Carver 350 aft cabin shat bolt issues
Posted: October 17th, 2023, 4:53 pm
by ataylor233
sooo this happened
its supposed to be here
the boats sheered long story short i need to find replacement bolts
does anyone know what size they are they are round head square neck bolts i need to know the material and length
Re: Carver 350 aft cabin shat bolt issues
Posted: October 17th, 2023, 8:00 pm
They are likely silicone bronze carriage bolts.
https://www.mcmaster.com/products/silic ... age-bolts/
Don't know the diameter, but you should be able to find it with the existing bolts. Inside the boat, where you'd have to tighten the nuts, the rest of the bolt should be laying there (or still stuck in the hole).
Posted: October 18th, 2023, 6:28 pm
by plittle2005
The bolts are the least of the problem. What caused the bolts to shear and what other damage has occurred. Did you hit something? If fatigue due to vibration, the vibration must have been severe for a long time. Looks like some extensive inspection and repair.
The cutless appears to be worn. If both this cutless and the strut end were so loose that the vibration actually caused bolt failure, the gland, shaft, coupling and main strut damage could be severe.
And how worn is the other shaft assembly?
