Need obsolete parts
jema
Vessel Info: 1991 Carver 430 Aft Cabin. Twin Cumins 6BTA 5.9
Need obsolete parts
Post by jema »
I need to find the vent covers for intake/exhaust on the side of my 1991 430 CPMY. They measure OD 17 1/4“ x 2 1/2” The inside (hole size) is 16” x 1 7/8”. There are 8 in total covering both sides. Any ideas where I might start looking. I’m in Canada.
Re: Need obsolete parts
Post by Midnightsun »
jema
Post by jema »
Thank you. Those ones are a bit over-sized. I'm trying to avoid modifying the hole.
Post by g36 »
I believe this is it. Not 8 and located in usa. Although not cream....https://www.google.com/aclk?sa=l&ai=DCh ... g96BAgBECA
Post by g36 »
See these check on the specs listed. . 8 oems maybe impossible or costly to find. These are the same overall length and will fit in the oem cutouts with no mods. purchasing 8 to be new all around. https://www.go2marine.com/Sea-Dog-Louve ... OgQAvD_BwE
Been thanked: 248 times
Post by mjk1040 »
That looks like the ticket g36! I was going to suggest going to metal ones, the plastic ones fade and get brittle so fast.
Has thanked: 605 times
Been thanked: 1313 times
Jema .....is there a name or part number on those old ones ?
I think most anything you find used or a salvage yard would probably need some sort of resto to them ( paint etc )
This might require some fitting to get the right look you are after.
mjk1040 wrote:QR_BBPOST That looks like the ticket g36! I was going to suggest going to metal ones, the plastic ones fade and get brittle so fast.
The trick for the plastic ones is to paint them with high quality paint, they will never yellow and will last a lifetime since the plastic is now sealed from UV light which is what kills them over time. Did just that to a prior boat as they really were yellowed and looked pretty bad.
