Carver Drive shafts
Ernie Pozz
Vessel Info: 420SS 2007
Carver Drive shafts
Post by Ernie Pozz »
I have a 2007 Carver 420SS. Broke two shafts within a month of each other. Less than 300 hours. Mechanic says its either a problem with design or quality of metal used. Anyone else have this problem? Sent a note to Carver and not getting any response.
Ramsport47
Been thanked: 59 times
Carver Drive shafts
Post by Ramsport47 »
I've never seen a Carver break a shaft. Was there any vibration while running the boat?
Kenny
T-Merc 350 Mag MPI (300hp)
Been thanked: 493 times
Carver Drive shafts
Post by waybomb »
Wow! That's all you need is a drive shaft bouncing around the inside of a resin hull! Better install some drive shaft loops.
Just kidding on the loops.
Did the shafts break clean at the welds, or was the shaft simply torn apart, as in ripped?
Carver Drive shafts
I've seen them break as a result of corrosion. On close inspection, you can see pinholes on the surface but poor quality SS will have cavities under those pinholes that can eventually grow and weaken the shaft. Not difficult to determine if that was the issue, just inspect one of the broken ends. Someone who knows what to look for will be able to tell if that was the cause. Short of that, the only other things I can think of is a previous bad impact that weakened the shaft but it was repaired instead of replaced (they're never the same after), or a very bad alignment, but for it to be that bad, you would have felt something more than just a slight vibration.
JediJD
Vessel Info: 2007 Carver 42SS
Woodstock, GA
Carver Drive shafts
Post by JediJD »
Not sure that I have anything to add, but we have an odd squealing noise coming from what appears to be the driveshaft opening (where the shaft seal fits) to port. I was figuring a pull and a cursory review, but I have a 2007 42SS as well and now I may have it much more carefully inspected...thanks. Also have a buddy with one (same year) I'll pass along.
Charles Robertson, USCG Master Cpt.
Lakes Allatoona and Lanier, GA
'07 Carver 42SS "A Little More Nauti"
(tender is a '15 VX Cruiser "Littler Nauti"
'03 Sea Ray 380DA "A Little Nauti" (sold and missed)
timjet
Vessel Info: '98 Carver 355
Twin Cummins Diesels
Carver Drive shafts
Post by timjet »
This post was on another boating forum with several responses but nothing further from the OP. Unless we hear back from the OP I consider this a slam post against Carver and nothing more.
Carver Drive shafts
I saw that
