Access to Trick Davits
rfverdery
Vessel Info: 2001 Carver 466. Twin TAMD 74 P 480 Volvo’s.
Has thanked: 26 times
Been thanked: 2 times
Post by rfverdery »
I have a set of trick Davits on the swim platform of our 2001 466. The bolt heads are carriage and recessed. Can anyone tell me how to access the end of the bolts inside the swim platform in order to remove the Davits completely. Thank you.
Been thanked: 1313 times
Re: Access to Trick Davits
Have a quick look under the platform for those screw in access plates.....
rfverdery
Post by rfverdery »
Thank you. I have looked on the underside and nothing. It seems as if they are in the hollow section of the platform I just can’t figure out how to reach them!
rfverdery wrote:QR_BBPOST Thank you. I have looked on the underside and nothing. It seems as if they are in the hollow section of the platform I just can’t figure out how to reach them!
Too bad , that was the easy one......looks like you might be destined to taking drawers and things apart to access the void or at least have a look in there unless there is a way thru the transom box. Thing is you just are never sure what someone before has done.....good luck man.
Drspikes355
Vessel Info: 1996 Carver 355 aft cabin Crusader 454’s
Has thanked: 135 times
Been thanked: 3 times
Post by Drspikes355 »
Trick Davits we’re likely installed with toggles inside that expand. Try to back the bolt head out and pry a bit between the bottom of bolt head and platform.
I inquired and talked with Jim Trick himself, that was his idea of mounting on that style of Carver.
Hope this helps- let us know.
