2006 Carver 36MY trim tab reservoir fill
- KPT
Thanks.
- Carverlvr2
- Been thanked: 4 times
Re: 2006 Carver 36MY trim tab reservoir fill
- Has thanked: 457 times
- Been thanked: 1675 times
- Has thanked: 269 times
- Been thanked: 1155 times
Make sure you're checking and filling the reservoir with the tabs fully retracted (up). If oil loss has happened within a short period of time, you should be looking for leaks. While at the pump, check all the lines, fitting, and pump for telltale signs. The most common leaks though are at the actuators on the tabs. Also check the condition of the fluid currently in the reservoir, it should be ruby red. If it's a creamy colour, the system ingested water and needs to be remedied to prevent pump damage.
Users browsing this forum: Msquared and 15 guests
