bow thruster in a 4207
- glennmac
- Vessel Info: carver 4207 aft cabin
I am thinking of installing a bow thruster on my 1991 4207. has anybody done this? It looks like I might have to cut a hole in the floor of my forward cabin to get to an area where the motor and tunnel go. Is this doable, or will it weaken the hull in any way? Any thoughts or insights would be greatly appreciated
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Re: bow thruster in a 4207
I have watched "several" videos of this. My conclusion is that unless you are really good with fiberglass and gelcoat refinishing hire a professional for the job!!!!
Cheers
Fraser
Cheers
Fraser
Former 2001 350 Mariner owner
As long as you don't cut through a cross member that might be there bracing stringers, just cutting access in the floor for this application won't weaken the hull.
Are you doing the installation or having someone do it for you?
