1986 Carver 3207 Water system
ataylor233
Has thanked: 83 times
Been thanked: 7 times
Post by ataylor233 »
I just Recently purchased a carver 3207.1st. i dont see a shore water connection only a water inlet i believe for the tanks.The water pump was bad and disconnected but not replaced no hoses are connected to it ... what would be super helpful if someone took a picture of their system there the pump it .... so i can see what goes where... this is my first carver and i am stomped it looks as if the system was tweaked maybe to bypass the tank .
Been thanked: 248 times
Re: 1986 Carver 3207 Water system
Post by mjk1040 »
Check other 3207's online. Appears shore water was an after market add on and not an OEM option. Simple addition with PEX and quick attach fittings. Then just tee shore water line in after the pump on the outlet line. I would suggest re-plumbing all I could with PEX and quick attach fittings, IMO. Depending on the new tank pump you install, you may have to include a check valve after the pump out let and tee and you will also need a check valve after the shore water inlet depending on the type of shore inlet you decide to install. Many of the new shore water inlets have a check valve and pressure regulator built in. Your tank pump plumbing is simple, line from holding tank goes on the inlet side of the pump. Good luck with your project.
ataylor233
Thanks for the help I will open the hatch and take a look at everything closely
Been thanked: 1114 times
If you have the grey plastic water lines, then plan on replacing them all at some point. They will (if they haven't already) start to crack and leak. I replaced all mine with PEX several years ago and am VERY happy I did. It's not that expensive to do and it also makes you find all the nooks and crannies in the boat because you have to follow the old lines to run the new ones.
ataylor233
km1125 wrote:QR_BBPOST If you have the grey plastic water lines, then plan on replacing them all at some point. They will (if they haven't already) start to crack and leak. I replaced all mine with PEX several years ago and am VERY happy I did. It's not that expensive to do and it also makes you find all the nooks and crannies in the boat because you have to follow the old lines to run the new ones.
yes i just looked at pex piping and i think im going to take some time and replace everything fist tonight im going to take a long look at everything
thanks for your input was it a hard thing to do?
It really wasn't hard at all. There were a couple spots that were hard to crimp because there was a "T" in an inconvenient place. I used the copper crimp style though, not the push-on EZ connectors. You're just following the old lines and sometimes can tape the new lines to the old lines to help pull them through a blind area.
Probably the toughest spot was in the rear head. On mine I had to go through like 3 90 degree turns without kinking the tubing... just took a little more time and patience.
ataylor233
km1125 wrote:QR_BBPOST It really wasn't hard at all. There were a couple spots that were hard to crimp because there was a "T" in an inconvenient place. I used the copper crimp style though, not the push-on EZ connectors. You're just following the old lines and sometimes can tape the new lines to the old lines to help pull them through a blind area.
thanks for the insight i like the idea of replacing the pipes just seems like i should on a boat so old
