2001 Caver 396 Rudder bearing Replacement
BostonDan
Vessel Info: Carver 396 MY
Larson Cabrio 290
Post by BostonDan »
Hello,
We have a deposit on a 2001 396. Seller is broke and is giving allowances for items that need attention from the survey. Rudder bearings are weeping while underway. During the haul the starboard side had 1/8 wiggle.
Thus I was hoping the group here has had experience with replacing them and at what expense.
thanks Dan :help:
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: 2001 Caver 396 Rudder bearing Replacement
Post by pepmyster »
I replaced 1 gasket for the weeping. Looks like rope soaked in wax. Not a big deal at all. I have the starboard side doing it a bit, going to do it when we are on the hard for winter. Youtube is your friend on this one.
BostonDan
Larson Cabrio 290
Post by BostonDan »
This Model uses "TIDES BEARINGS" through a FRP rudder tube that terminates above the water line. Does yours have the same setup?
pepmyster
8.1 Volvo Penta
Fresh water boating
Post by pepmyster »
Not sure, sorry. There was 2 large nuts on the shaft which compressed the rope type seal. loosened, replaced, re-tighten.
BostonDan
Larson Cabrio 290
Post by BostonDan »
That is sweet setup for you. Wish I had the same. :down:
