1997 355 Aft Cabin aux tank
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Re: 1997 355 Aft Cabin aux tank
- True-North
- Vessel Info: 1997 Carver 355 Aft Cabin, lower helm station, Crusader 454 XLi engines, owner since 2007.
- Has thanked: 12 times
- Been thanked: 4 times
buster53 wrote:Source of the post When it's comes to the aft aux tank, either completely empty it or use it on a regular basis. What I do, if I take a trip, that will use, say 100 gallons, I run both engines off the aux tank to get there and use the saddle tanks to get home. Doing it this way, I quickly use up gas in the aft tank which lightens the weight in the butt end of the boat.
That is exactly my intent-use it very regularly. After removing the check valves, one had some build-up in it and the other was clean. It turns out the reason neither engine would run on the tank was because it was empty.
- True-North
Thanks everyone!
- True-North
Users browsing this forum: No registered users and 47 guests
