Upper helm floor access
Roddono
Vessel Info: 1991 Carver 33 Aft Cabin
Has thanked: 26 times
Post by Roddono »
Does anybody have a recommendation on how to remove the upper helm floor cover on 1991 Carver 33 Flybridge? I am trying to run some new wires from back of instrument panel to arch for a night light. I have included pictures of panel. Thanks in advance.
Ray
Been thanked: 1792 times
Re: Upper helm floor access
Have you tried using an electrical wire fish? Or, if you see any cut wires under the helm that aren't being used anymore and are heading in the direction you want, you can use them to tape the new wire to then pull the old wire to bring the new one to the same area. I've cleaned up a lot of my wiring from the upper helm and used that method a lot. When you run something through there, attach some good quality twine and run it with the new wire. Leave enough at both ends so that you can attach future wiring to it next time you want to run through there. I use the strapping used for shrink wrapping, works great. I have some going from my engine compartment up to the flybridge bench, from the bench to the helm, and from the bench through the radar arch. Makes future installs way easier.
Roddono
Post by Roddono »
Viper wrote:QR_BBPOST Have you tried using an electrical wire fish? Or, if you see any cut wires under the helm that aren't being used anymore and are heading in the direction you want, you can use them to tape the new wire to then pull the old wire to bring the new one to the same area. I've cleaned up a lot of my wiring from the upper helm and used that method a lot. When you run something through there, attach some good quality twine and run it with the new wire. Leave enough at both ends so that you can attach future wiring to it next time you want to run through there. I use the strapping used for shrink wrapping, works great. I have some going from my engine compartment up to the flybridge bench, from the bench to the helm, and from the bench through the radar arch. Makes future installs way easier.
Great idea. I will do that.
Thanks.
Ray...
V12diablo
Vessel Info: 2001 Carver 356 Aft Cabin
Been thanked: 13 times
Post by V12diablo »
I just disassembled my fly bridge on my 356 for transport and it had a similar setup. I had to take out the side panel of the fly bridge (shown in the bottom of your first pic). That allowed me to remove the access panel to the wires and gain access to the run going down into the salon. There was a screw in the front and back of the side panel and then you should be able to pull it out.
Jason
Post by g36 »
x2 on leaving a extra string or pull wire for future needs
Roddono
Post by Roddono »
V12diablo wrote:QR_BBPOST I just disassembled my fly bridge on my 356 for transport and it had a similar setup. I had to take out the side panel of the fly bridge (shown in the bottom of your first pic). That allowed me to remove the access panel to the wires and gain access to the run going down into the salon. There was a screw in the front and back of the side panel and then you should be able to pull it out.
Jason
Awesome.
Thank you
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Post by chpsk8 »
Can concur that removal of that side panel will reveal a couple screws. I did caulk mine back up when I put it back together to prevent water from getting in. . There is a stunning amount of wire squeezed into that space. I had an engine that wouldn't start and the cause was a connection from the ignition to the engine that was made in that cavity. Pure luck that we found it. Bypassed it and hit the key and it started.
