Foul smell in salon bar cabinet, in 1999 450 voyager we have sanitized grey water tank and black water tanks
- SeaMo
- Vessel Info: 1999 Carver 45’ Voyager
- Has thanked: 4 times
- Pflat
- Vessel Info: 450 Voyager with 450;Cummins
- Has thanked: 3 times
- Been thanked: 5 times
Re: Foul smell in salon bar cabinet, in 1999 450 voyager we have sanitized grey water tank and black water tanks
I would check the engine room, the guest head vacuum pump is located on the port side. The bellows on the pump on mine split and it took me awhile to figure out where the smell was coming from. You also might have sanitation hoses that have become gas permeable. The hoses run right across the forward bulkhead in the engine room. I’m not sure but the wet bar might be right above that bulkhead.
Good luck,
Pete
- Has thanked: 455 times
- Been thanked: 1671 times
If there is a sink on top of that cabinet, check to make sure nothing is wet in there that might be causing the smell like rotting wood. Can you get into every area of the cabinet's cavity? A dead rodent may be in a hidden spot. Now there's a horrible smell. If you keep using the boat the way you are and the smell gets less intensive then goes away without doing anything, it could very well be something that died and has dried up over time. Morbid but I've ran into that on boats, don't know how they get in though, I suspect engine compartment grills.
Users browsing this forum: No registered users and 56 guests
