Click Flooring
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: Click Flooring
Post by ColRon »
Viper, I too am looking to upgrade my interior flooring. The admiral wants hardwood look throughout the interior. I’ve been looking at Cali Fozzilized bamboo flooring it supposedly has a high Janka hardness rating. It is the click together style, but it can also be glued down. In my Santego I already have some parquet wooden flooring that came from carver and it has no 1/4 to 1/2 gap at the walls. So my concern is I would want to install it in the same manner as Carver originally did with theirs. The Cali stuff looks very similar to the Carver stuff in color and thickness. It is my understanding that glue the stuff down reduces expansion. Does anyone know of that is true? Leaving a gap at the wall present problems as it’s not always straight but curves eliminating using a quarter round strip to cover the gap. The Cali Bamboo can be purchased at Lowes.
Ron
“Escape Plan”
Murray, KY
:usa:
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 154 times
Been thanked: 149 times
Re: Click Flooring
Post by KyleR »
This is the stuff we used when we redid the stairs in our home. The bottom stair had a significant bend requiring a 180deg quarter-round wrap. This worked amazingly for hiding the gap on the bend:
MV Verity
2002 Carver 396
Re: Click Flooring
Ya Ron, I have the same concerns. I'll check out the Cali too.
Kyle, thanks for the tip re the flexible quarter round. I really don't want to leave a gap but if there is no choice it's good to know there are options to hide the gaps at curved areas.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: Click Flooring
Post by Tireless »
I am looking at replacing the carpet in my salon area. I am leaning towards a vinyl product that I can glue down do to the hatches to expose the bilge. I have been speaking to a friend about the type of vinyl that can be glued down. You can’t glue down all vinyl. If the vinyl has a backing on it, it can’t be glued down as the glue would react to the backing.
There are also PVC products that I am considering. Al Stuckless, (Als Marine Service) who is a member of this web site deals with and installs this all the time. It has a teak/holly appearance. Check out his web site. He is located in Kingston, Ontario, but he is the the Georgian Bay Area all the time.
I was on a brand new 60’ Cantius the other day, and they are installing vinyl floors in there boats now. I have decided that wood or laminate is not a good option for us.
Greg
Re: Click Flooring
Tireless wrote:QR_BBPOST ....If the vinyl has a backing on it, it can’t be glued down as the glue would react to the backing.....
Greg, what kind of backing are you talking about that can't be glued? They all have a backing material of some sort. Some are up to about 1/4" thick while others are less than 1/8"
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Re: Click Flooring
Post by Cooler »
Have you looked into the Infinity Luxury Woven vinyl products? Purchase in rolls, very easy to cut into custom patterns, and cleans up like magic. Check this link.
https://marinecarpeting.com/samples-of- ... n-teak-ii/
Hopefully, the video will load showing how easy it cleans. They pour engine oil on it, ketchup & mustard, etc., and it wipes off like magic.
Viper - if this interests you, let me know. If you are willing to drive to lower Michgan, I have a contact for you. 8-) er
Cooler By The Lake
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Re: Click Flooring
Post by quickdecision »
Try Lonseal flooring, 10 years no problems. Wears like iron. Look at Plasteak. You make template they CNC floor for perfect fit.
Ron
Tireless
Re: Click Flooring
Post by Tireless »
Viper, most vinyl flooring has a backing on it from what I have seen. Normally it is a vapour or sound barrier. There are vinyl products out there that do not have a backing. If you go into a flooring store they will advise you. The selection is not as plentiful as with the flooring with backing.
The backing are normally a rubber or foam backing that is a problem for gluing down.
Greg
Re: Click Flooring
Thanks guys, the search continues.
