I did my first generator service on my 1 year old to me 1998, 405 AC. The genny is a Kohler 10kw, model 10e gas burner. It’s always operated great. Sometimes it takes three tries to start it, but always starts. I figured probably needed plugs as to why it doesn’t start right away?
I ordered a maintenance kit from EBay and it came with:
Champion plugs
Fuel filter
Oil filter
Water pump belt
Slow burn fuses
Impeller (but was wrong impeller, I could have an after market pump housing??)
Anode
I changed oil, oil filter, fuel filter, belt, plugs, & anode. Will have to wait until I get correct impeller then will change it.
Not sure what the deal was on the anode? The old anode brass fitting looked like it had been in and out multiple times? Maybe previous owner used same brass fitting but just put in new anode?? None the less here’s some pictures. Based on this I highly recommend checking the anode!!
The pics are rotated 90* clockwise. I’ve not figured out how to fix that yet!!
Generator Anode Change
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
1959 Larson 16’
1979 Caravelle 18’
1979 Caravelle 18’
- Been thanked: 654 times
Re: Generator Anode Change
This is the impeller for my 405 Kohler 10 genset. I would think yours is the same...Kohler 229826
OR Sherwood 09000K
or Sierra 23-3303
PS, they sell just the anode itself and you can reuse the same fitting if you can get the remainder of the anode out of the threads. If you replace on a regular basis, the anode should unscrew from the fitting pretty easy. Having said that, it's best to simply replace the entire assembly after the fitting has been removed a few times.
or Sierra 23-3303
- Mikwallace
Found the correct impeller - Kohler 25-0872; replaced by 229955. The pump is a Kohler 267373. Old School equipment.
1959 Larson 16’
1979 Caravelle 18’
1979 Caravelle 18’
Interesting, the Kohler model 10E should be impeller 229826. Unless there are other kits with the same impeller but include other gaskets, seals, etc.
- Been thanked: 1313 times
Curious....how many bolts/screws does the pump cover plate have ?Mikwallace wrote:QR_BBPOST Found the correct impeller - Kohler 25-0872; replaced by 229955. The pump is a Kohler 267373. Old School equipment.
- Mikwallace
Mine has 6 screws on the cover with a gasket, not an o-ring.bud37 wrote:QR_BBPOSTCurious....how many bolts/screws does the pump cover plate have ?Mikwallace wrote:QR_BBPOST Found the correct impeller - Kohler 25-0872; replaced by 229955. The pump is a Kohler 267373. Old School equipment.
Here’s a link to what mine looks like:
https://a.co/d/fzZ17uJ
1959 Larson 16’
1979 Caravelle 18’
1979 Caravelle 18’
