Best method for fixing stripped exterior hinge mounting screws
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Postby theorifice » May 28th, 2024, 3:30 am
What's the best way to fix these stripped mounting hole screws? They're for the covers for bins on the aft deck:
Fun times on the 1988 Carver Santego 30
Has thanked: 270 times
Been thanked: 1159 times
Re: Best method for fixing stripped exterior hinge mounting screws
Postby Midnightsun » May 28th, 2024, 9:43 am
Only time I needed to do this was quite some time ago where I used Marinetex. Worked wonderfully by the way.
I would drill out the hole just slightly so as to expose clean fibreglass all while removing the crud in the hole. Fill hole as best you can and when dry, drill out to appropriate size the take the screw. Do not need to fill it full, just enough to be able to drill out and have a hole the size required to get the original screw back in. https://itwperformancepolymers.com/prod ... poxy-putty
Been thanked: 620 times
Postby g36 » May 28th, 2024, 11:11 am
I've used this product. It mixes as you are squeezing it out sou only use what you need. Drill out the holes abit larger like was mentioned and fill with this and after it sets redrill it.
G/Flex 655-1 1 oz syringe https://a.co/d/bPIXa7O
theorifice
Postby theorifice » August 25th, 2024, 5:22 pm
Thanks all. Cleaned and drilled the holes out and packed in some marinetex. The hatch mounted up no problem after.
Users browsing this forum: No registered users and 85 guests
