1991 Carver 26 Command Bridge: Shower sump pump location
c44588
Vessel Info: 1991 Carver 26 Command Bridge
Re: 1991 Carver 26 Command Bridge: Shower sump pump location
Postby c44588 » January 7th, 2022, 5:18 pm
Thanks for all the great references/recommendations. Will be going to the boat next week and will get some pics for you folks and check out the layout against what the schematics are indicating.
I bought the boat brand new. Still had the shrink-wrap from the factory transporter on it. All original and going on 30 years now...My little baby....
Jack
c44588
Postby c44588 » February 20th, 2025, 5:05 pm
Let me know what pics you'd like and I will provide. I do not have a switch on the wall for the shower pump as you suggest, nor did I locate any pump in the engine room that would fit your description. I think I will need to add a sump and pump set and fit both the shower and A/C drain into it as both drains currently end up in the bildge.
Users browsing this forum: Google [Bot] and 121 guests
