Just something for those of you that use rotella on your gas engines.
Re: Just something for those of you that use rotella on your gas engines.
Zinc does help with lubrication but has side effects at higher levels in gasoline engines. Too much zinc as that found in diesel oils has undesirable effects in gasoline applications, especially hotter running marine engines. And that's where I'll stop beating the dead horse ;-)
Viper wrote:QR_BBPOST especially hotter running marine engines.
Heh the horse lives....like that Schrodinger thing :-D ... yep, but don't marine engines run cooler... raw water cooled thermostats spec at 142 or so in salt.
Not in the combustion chamber, in gear they're always under higher load than an automotive application, always on the verge of pre-ignition and detonation which are taken into consideration in gasoline oil formulations so they handle combustion by-products that can lead to these and other conditions. The rest of the engine doesn't get as hot by design thanks to the cooling and lubrication systems.
Let me get off the horse already ;-)
Viper wrote:QR_BBPOST Zinc does help with lubrication but has side effects at higher levels in gasoline engines
I fully agree,..... one point to consider in this though , diesel combustion chambers run at much greater temps than gasoline due to the fuel and compression almost two times in some cases.
W The fact of it is we used the zinc to protect the valve train in flat tappet engines like has been mentioned. Now all the gas engines are roller as far as I know and have been for some time now so no need. Too many opinions out there including mine and yours.
Looks like the saddle has some glue on it... :-D ... ;-)
Post by Midnightsun »
Just giving the horse a jolt to bring him back to life. :-D
One must specify which Rotella one is referring to because this Rotella is recommended for Diesels and Gasoline engines. :popcorn:
https://rotella.shell.com/en_ca/product ... 9lbl9jYQ==
Should also mention regular T4 Rotella IS SN rated. What is the SN rating? The newest standard for gasoline engines as can be seen here and does cover engines . https://www.gopurepower.com/blog/a-guid ... motor-oil/
Check out the spec for Rotella T4 oil (SN Rating) here. https://www.traction.com/en/p/rotella-t ... e550045128
OK, we can kill the horse once more. ;-)
