Apleco 530 deep sounder
Wkuhilltopperfan
Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
Has thanked: 17 times
Been thanked: 18 times
Post by Wkuhilltopperfan »
My display has went bad on my Apelco 530 depth gauge and we are looking for either a replacement display or a compatible display to mate to the original transducer so I don't have to remove the boat from the water just to replace the transducer which is expensive as everybody knows. Any help on compatible displays or used 530's would be great. We don't use the plotter , only the depth gauge.
Thank you
1998 350 Mariner
Re: Apleco 530 deep sounder
Post by g36 »
i have some apelco stuff i used to use at home not sure at the moment which model if you would like i will check. let me know if you havent moved on to something else.
Wkuhilltopperfan
g36 wrote:QR_BBPOST i have some apelco stuff i used to use at home not sure at the moment which model if you would like i will check. let me know if you havent moved on to something else.
I think the Apelco 560 is also compatible from what I hear. If you have a 530 or 560 ..... That would be awesomeness
1998 350 Mariner
Post by g36 »
Sorry what I have is 260
Wkuhilltopperfan
Thanks for checking, it's appreciated
1998 350 Mariner
