Californian 45 packing size
Hotei
Vessel Info: 1990 californian 45
Post by Hotei »
I have a 1990 Californian with 2" prop shafts. The packing nuts have bottomed out and I need to add some more packing. It's not a problem to add the packing in the water, IF I have the correct packing to add.
Can anyone tell me what size packing is used?
Been thanked: 1313 times
Re: Californian 45 packing size
There are different makers of the packing glands and they use different size packing with the same size shaft......so you may have to measure the ID of the nut and 1/2 the difference between that and the shaft size would be the size you are looking for.....2'' shaft and nut ID of lets say 2 1/2"-----diff 1/2" divide by 2, would be around 1/4" packing..just an example for you.....good luck.....you probably already know this but....... :beergood:
You could try calling Carver and give them your hull number if you don't get a definitive answer here.
Where is she berthed? Don't recall ever being in one up here.
Hotei
Post by Hotei »
The Hotei is at Lambs Yacht Center in Jacksonville.
