Kariba Washer / Dryer Combo
mikekomm
Vessel Info: 1989 4207
Post by mikekomm »
I have a Kariba washer / dryer combo on my '89 Carver 4207. It takes 2 hours to dry most loads. Is this normal? I'm in Southern Calif with pretty dry climate even on the water. Any ideas? Is Kariba still in business?
Ramsport47
Been thanked: 59 times
Re: Kariba Washer / Dryer Combo
Post by Ramsport47 »
That is a pretty normal time for these combo units.
Kenny
T-Merc 350 Mag MPI (300hp)
tc'sbackporch
Vessel Info: 1987 carver 4207
Has thanked: 6 times
Post by tc'sbackporch »
mikekomm wrote:Qr Bbpost I have a Kariba washer / dryer combo on my '89 Carver 4207. It takes 2 hours to dry most loads. Is this normal? I'm in Southern Calif with pretty dry climate even on the water. Any ideas? Is Kariba still in business?
where is the unit located we want to put one on our 4207
Been thanked: 492 times
Post by waybomb »
Use the washer/drier at a marina.
I can't stand these combo units. They take forever.
I believe the 4207 had its washer on the port side, in the first cabinet at the steps.
Wzdr02
Vessel Info: 1988 Carver 4207 w/CAT 3208TA
Has thanked: 2 times
Post by Wzdr02 »
I've seen them in 4 locations. to stbd of the stairs going into aft state room as a combo in the closet this is the version we have, to port in the sliding door closet either as a combo or as side by side, in the pantry just fwd of stove stacked version and extend closet 5 inches inboard to port and lastly in the engine room where the hot water heater is and the heater is in the salon where many models have an ice maker.
We are going to rip out the ventless combo and in stall a washer in its place with a vented version in the sliding door closet port side aft stateroom. The reviews of the Combo washer dryers are horrible. I dont want to rip out the port side window to replace these along with salon furniture and Fridge once.
