Page 1 of 4
Rotella T4 15w 40
Posted: October 10th, 2019, 5:40 pm
by Midnightsun
Did my oil changes and all the filters on both engines and generator today. I always used Rotella T4 in my previous gas engines, the SeaDoo and even my summer ragtop. Needless to say I use a lot as the boat alone requires about 12 gallons. They have 5g pails of T4 at Walmart for $57 and some change CDN. Probably the cheapest I have ever seen it as of late. Bought 3 more pails for next years oil change. :-D Not sure if this is provincial or Canada wide.
Oddly enough everything in the states when it comes to gas and oil is always cheaper, exception Rotella. That comes to $43 US for 5G.
Re: Rotella T4 15w 40
Posted: October 11th, 2019, 5:51 am
by pepmyster
Thanks for the heads up! Did my oil changes already, and, only use Rotella also.
Posted: October 11th, 2019, 5:56 am
by mjk1040
Found out Tractor Supply Brand is Rotella, same oil different label. Do u have a Tractor Supply in Canada?
Posted: October 11th, 2019, 6:01 am
by Midnightsun
As for availability it seems to be all of Canada. https://www.walmart.ca/search/rotella%20pail
Posted: October 11th, 2019, 6:06 am
by Midnightsun
mjk1040 wrote:Source of the post Found out Tractor Supply Brand is Rotella, same oil different label. Do u have a Tractor Supply in Canada?
I do not believe we have those here.
Posted: October 11th, 2019, 9:01 am
by g36
didnt know about tractors supply being rotella howd you find that out?
Posted: October 11th, 2019, 3:42 pm
by vineyardgray
Isn't TSC the same as Tractor Supply?
Posted: October 11th, 2019, 6:30 pm
by darrenlife
I don’t mean to open a can of worm but I thought I read somewhere that Shell changed their Rotella formula to contain less zinc and may not be as useful in gas engines?
I always used Rotella on my previous diesel boat but am paying out the nose for the Merc 25W40 semi-synthetic, would love to go back to Rotella
Posted: October 11th, 2019, 7:15 pm
by tomschauer
Darren, I have always run Mobil 1 15/50 full synthetic in my merc gassers. Cheaper than the merc semi, and better oil.
Posted: October 11th, 2019, 9:34 pm
darrenlife wrote:Source of the post I don’t mean to open a can of worm but?.....
I'll open up another can of worms; in all my OEM training, we've always been taught that Dino oil has a shelf life of a year in an unopened container and that you shouldn't use oil from a container that's been opened for more than 6 months. I prefer not to use anything that's been opened for more than 3 months. Now maybe it's marketing but it is true that Dino oil and additives start to slowly degrade over time. With this in mind, consider that when you buy oil, it may have been on the shelf for who knows how long, then you're keeping it for a year until your next oil change, then you're expecting it to be in you engine for a year and expect it to perform to spec. For this reason, I only buy oils when I plan to use them right away.
