Cutlass bearing replacement determination - 1984 Mariner 3697
Posted: January 2nd, 2023, 8:51 pm
by rictamily
Hi,
My prop shaft is 1 ⅜ diameter. I have the boat on blocks so wanting to do maintenance while on the hard. The props are removed and when shaking prop shafts there is movement...movement enough to make a slight clunking sound when emphasized. Is there a certain tolerance?
Also, is the process of replacement just a cutlass bearing-removing tool to remove and replace? Or are other calibration methods required?
Re: Cutlass bearing replacement determination - 1984 Mariner 3697
Posted: January 3rd, 2023, 4:46 pm
Here is a quick reference i came across.......can't specifically answer your clearance question as I don't know....
https://www.pacificmarine.net/engineeri ... arance.htm
Posted: February 8th, 2023, 8:19 pm
by rictamily
Thank you so much for your time.
