water in the bilge... Hmmm?
Posted: April 2nd, 2023, 8:25 am
Ok, this is an odd one for me and am wondering your thoughts:
2003 Carver 396 aft cabin is my boat.
She was in heated storage for the winter and launched last week. The water temperature was 38F (these details will be brought up later)
A couple hours after launch I was checking my bilge pumps and bays, only to find water in the aft most bay near the drain plug. My boat has ALWAYS been dry as a popcorn... well, its dry! So this came as a bit of a shock to me to find water.
I used a hand pump to get as much water out of the bay as possible. water was not RUSHING in, by any means, but it was coming in. I would say it was growing at about 1/2 gal an hour. The next morning, the water was back and to a level where I believe the bilge pump had kept it overnight. I got a shop vac to completely dry the boat out and had sucked out a good 30 gal of water.
I was then with the boat for a good 3-4 hours and no additional water seemed to intrude or accumulate. I had to leave the boat, and will not be back for 3-4 days. (don't worry, my marina and friends are watching it for signs of trouble.
To add more details: no other area of the boat show any signs of water:
* All sea trainers were dry
* eng compartment... dry
* Fwd compartments .. yep dry
Here is my wonder
Could the rapid change in temperature (65f in the building to 38f water temperature) be enough to expose some issues with the drain plug? I don't believe there is any teflon tape on the plug but I'm guessing as I have never removed it or had the need as its always dry in there. My only thought is could expansion/contraction due to temperature played a small impact here where the drain plug (which is the only thing in the back area where the water was) played a part. Could 1 material not adjusted to the temperature change as fast as an another allowing the water to intrude and as it adjusted the leak stopped? seems far fetched to me, but about all I can think of.
Here is my wonder
er
