Generator rpm
Jmatheson
Vessel Info: 1997 carver 405 aft cabin
Has thanked: 4 times
Generator rpm
Post by Jmatheson »
My generator will not maintain rpm. It swings up and down continuously until sometimes it dies at the low end. This happens when it's on load or not. Thanks.
Re: Generator rpm
Post by tomschauer »
It may be as simple as a governor spring unhooked. If you post a model number, someone most likely has a manual.
Been thanked: 1313 times
Re: Generator rpm
If this is a gas generator......Could also be a partially restricted jet causing the engine to run lean,( hunting ) by the sounds of your explanation .....also there is an adjustment for idle mixture on the carb which may help a bit , but you need to read the manual to adjust only the mixture screw.....never adjust anything to do with rpm........ :beergood:
Been thanked: 1114 times
Re: Generator rpm
How long have you run it? What kind of load do you run it on?
If it's not something simple (like the spring) then definitely sounds like a fuel condition. These don't typically get run a lot, so you can end up with carb issues from lack of use.
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Re: Generator rpm
Post by Agriman »
Is the water pump showing good volume flow? Low water volume will cause the generator sensor to shut down to protect the unit. You might need a new impeller.
