Looking for a gear linkage for a 1988 Voyager 28
- Darkfaythe
- Vessel Info: 1988 Carver Voyager 28
- Contact:
Hi all
I dont know if this is the right place to be asking this but I have a 1988 Voyager 28 with twin Chev 305's and V Drives.
One of the linkages from the V Drive to the prop shaft is bent and I'm trying to find a replacement.
It is a Walter V-Drive with 1 1?4" shaft and standard SAE taper with 5/16" key.
Does anyone have any suggestions please?
Cheers
Rob
Cheers
Rob
- mjk1040
- Been thanked: 248 times
Re: Looking for a gear linkage for a 1988 Voyager 28
Rob do u have a picture? How did it get bent? Is this in the boat or under the boat. Need more info here!
Mike
- Darkfaythe
- Contact:
Hi Mike
I have attached a graphic from the manual outlining the prop shaft coupling and thats the bit that seems to have worn 'out of true' from when the previous owner put it in crooked.
I can access this from in the boat so no problem there and its currently on its mooring anyway.
Hope this helps. I can photograph the segment when I go over the to boat on the weekend if necessary though.
Cheers
Rob
Cheers
Rob
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
If it is the shaft coupler you need they are replaced by supplying the specs:
Shaft size
Flange diameter
Couple type, tapper, split, reverse taper, etc.
Transmission type
A good prop shop should match a replacement. Go on line and search "inboard shaft coupler"
Shaft size
Flange diameter
Transmission type
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Darkfaythe
- Contact:
Hi
Thanks for that. Both myself and my mechanic have been unable to find anything here in New Zealand hence my trying a little further afield.
It is a Walter V-Drive with 1 1/4" shaft and standard SAE taper with 5/16" key.
Cheers
Rob
Cheers
Rob
You're looking for a shaft coupler. Like dsolo said, a good prop shop should be able to help and ship one to you. Maybe one of the guys here from the States can recommend a good shop on this side of the pond or you can try United Propeller in Ontario Canada: http://www.unitedpropeller.ca/ ask for Amanda, I deal with her all the time, she knows her stuff. You can also try the Walter Machine Co. http://www.waltergear.com/.
If it's in the condition you describe, unfortunately you may need to dress/machine the tranny flange. If it's warped as a result of the coupler's condition, you need to make sure that gets corrected first. It would have to come off and sent into a shop to be refaced or you'll still have a vibration no matter what you do.
- Darkfaythe
- Contact:
Many thanks for all your help people. I know have some good leads to follow up on.
- Been thanked: 1313 times
If all else fails in your search, I would probably take both sides of the coupling to a machine shop, I am sure they could make that stuff up for you....they understand taper fits etc....just a thought.....
- Darkfaythe
- Contact:
Yes, I know what you are suggesting. I have already done that with the prop shaft. THat has been machined spot on before re fitting it into the boat as I replaced the stuffing box at the same time, so its just the shaft coupler now. I am following up on the suggestions above for that right now.
- mjk1040
Ok, glad all worked out. When you first said linkage instead of coupler I was puzzled. It concerns me how that got so out of shape to begin with, whatever it has to be fixed now. Good Luck!
Mike
